Smelling tranny fluid.
notenuftime
Pennsylvania
changed my clutch and flywheel and also tranny fluid transfer case fluid. Now every so often when shifting threw the gears and at lower speeds I can smell transmission fluid, maybe getting hot. What might be happening here.
Well.... feel it and see if it's getting hot.
Did you fill the trans from the shifter hole?
notenuftime
Pennsylvania
Crawled under the other day when I smelled it felt hot to the touch. I filled from underneath.
notenuftime
Pennsylvania
May look around the clutch area.
Just looked everything is dry. Could it have something to do with my engine being not timed yet maybe not working right with gear and revs.
tke395
