Single Flash of ABS Dummy Light Followed by constant on?
mankypro
Learning Slowly...
Boulder County, Colorado
Checked all my fuses, all OK. Does the single flash tell me which sensor is bunk or what to repair? I'm not too keen on spending $85.00 for someone to pull my ABS codes. My code reader doesn't pull ABS codes...
2001 Ford Excursion 7.3l
Mike
Stroker
Cora
Have you done a simple check of the VSS yet? Its a reach but it might be dirty.
mankypro
Learning Slowly...
I'm sorry, VSS, vehicle speed sensor? wild guess there. what is it and where would I find it?
You're not talking about the speed sensor in the rear diff are you? If so it's been replaced.
