Simple way to get rid of sludge from fuging
Mt_Man
Portland, Oregon
Not sure if this is particularly unsafe or environmentally friendly but I feel it's better then taking it to the oil recycle or dumping in the dump. I have burned the stuff in soup can in wood stoves, super hot burn pile, and blended with some oil and taken to recyclers.
This took a while to boil the water off to get it to burn nicely. I could smell the difference when all the water was gone. My hot plate was pretty under powered for the job.
What do you guys do?
u2slow
bilge rat
Coastal BC
Burn-pile or backyard 'camp' fire is where my rags and sludge go to. No centrifuge yet. I would bucket it for recycling if I had a lot.
Fattima
Australia
I send it to the oil disposal at the local tip. With waste veg oil and veg oil with too many solids I mix it with hardwood sawdust I get from a local furniture maker. Put the mix in small cardboard boxes and burn them in my wood heater. They pack a punch and really reduce the amount of wood I have to burn. I did try the same idea with some WMO, in a really hot fire it burnt well but was a bit smokey and you could really smell it. WVO you can barely smell.
