Setting Inj Pump timing with a multimeter
Michael Fowler
Bel Air, MD
There is a long thread over on the Mercedes Shop Diesel forum about setting the injection pump timing using a multimeter to read millivolts. It seems that anything made with dissimilar metals will generate electricity when subjected to hear. Glow plugs are such a device.
It is said that by reading the voltages generated by the glowplugs, you have an effective thermocouple into the combustion chamber. There is some debate over which point is the preferred "correct" timing point--with some saying at the point where the highest voltages ( temps) are seen, while others say it is just to the retarded side of that point.
I don't know. But wouldn't it be great if we could time our engines that way? One guy claims 1/10 of a degree precision.
I could post a link, if its allowed, but if not you could find it yourselves.
What do you guys think?
highest_vision
Reqistered User
Boone, North Carolina
You may be able to find a voltage for your engine the first time you do it, but it won't likely be the same next time or for anyone else. There is also the potential for stray voltage to affect your reading (ever tested coolant voltage?). You could probably make your own deal to use with a timing light with a photo-electric diode or a knock sensor and assorted electrical components.
James
I agree with James. Heck, the multimeter leads themselves could induce a sufficient problem when trying to measure such a small amount.
crispy74
