Rusty Truck Contest
69oiler
I don't feel tardy
Chardon OH
i should get some new pics, she looks even worse now with POR15 spots all over.
Fordman75
Lonsdale, MN
Somebody say rusty truck?:D LOL Not an IDI but definitely was rusty.
My 91 has rust but it's got metal riveted over the big holes holes (cab corners ) and has been painted over by the previous owner so it's all not visible.
Clydesdale
Nampa,Id
If I get this Centurion ex cab F250 IDI.. I will win.. will post pics when I get it.
you can see through the bed into and then through the frame in spots... Rather cool.
Freight_Train
Traitor to the brotherhood
Gadsden,Al
ok,not an IDI but.....you said Rusty Truck Not Rusty IDI....
tbirdscott
prince george b.c.
When I picked up my 84 it took two people to close the tail gate, one to hold the drivers box side up, another to slam the gate up. The cab corners are gone, floor has numerous holes, the original fenders which the PO swapped out barely held the inner fenders up.
Sat for two years on grass, you can tell good rust by the rich earthy reddish colour ;Sweet
Swapped the box with a better one (better being I can close it myself!) and doused it with marine enamel ($100 paint job) Been a pretty good truck.
I had a 79 that was much much worse, but it was runnin a 351M on propane :rolleyes:
Scott
Freight_Train
Gadsden,Al
wow,even the same Model too.M543A2 with a Multifuel.I would say....your Gramps truck is in a tad better shape.......Mine is a case of lock jaw waiting to happen!
88beast
pa
69 oiler you loose with that por 15 you can park at the bottom of a lake every night and stilll not rust again lol
heres my 2 contributions ones a jeep
the next is my idi
you shoulda seen the 6 by 8 hole under my feet before i fixed the floorboards
and finally my trailer its an m101a1 and looks like a pickup bed so ill throw it up
the brown on truck and trailer is fixed rust areas
Bill-W
GA
I'll play, it's not my diesel but rather an old Ranger. Came from NH and had a stock bed-liner on it. The bed was just the start of the issues the shock mounts rotted off the frame and the cross member that held the gas tank and the front end of the bed was in 2 pieces. Every time I'd work on it I would end up having to buy all new hardware as the old stuff would just disintegrate.
More pictures if you want
I love having a southern truck now with no rot! :thumbsup:
Danoflapper
Zeeland, Michigan
Dang there's some good (as in bad) ones so far!
The put the salt on pretty thick around here, roads are nice and white when they are dry.
My uncle has a glorified version of your trailer, she ain't rusty but still cool to look at
Bo17
