Rumor has it....Moose Injectors Rally Debut!
hesutton
The Anti-Anderson
Bowling Green, KY
Yup, I'm hopeing to have a set (the 1st actually) of Moose Injectors at the Rally for a pop test (if Ron or Gary can squeeze a tester in their trucks), installation, and a dyno run. I'm not going to be 100% moose, as I'll still have the DPS IP, but I'm not real happy with the less than stellar characteristics of the DPS stage ones.:dunno
You'll see the difference between the DPS "*******" and the Moose "misters".:D
I was going to wait, but I couldn't help but spill the beans.:D
Heath
hesutton
The Anti-Anderson
Bowling Green, KY
Actual cost is unknown but it will be about $100-$125 per injector (yup that's $800-$1000 for a set).
Heath
Dsl_Dog_Treat
Decatur,MI
Yup, I'm hopeing to have a set (the 1st actually) of Moose Injectors at the Rally for a pop test (if Ron or Gary can squeese a tester in their trucks) and a dyno run. I'm not going to be 100% moose, as I'll still have the DPS IP, but I'm not real happy with the less than stellar characteristics of the DPS stage ones.:dunno
Heath
Well I can't speak for Gary, but my "Fee" for testing Moose Misters will be an equal set in return.:D
Heath, I will be bringing the tester since I have enough storage now, having upgraded to the old Toshmahal, to even bring a second kitchen sink.;Sweet
hesutton
The Anti-Anderson
Bowling Green, KY
DANG!!! That's a serious labor charge!:kick::shocked::rotflmao
Thanks a bunch for bringing it! It will be cool to see it in action.:hail
Heath
hesutton
The Anti-Anderson
Bowling Green, KY
Honestly, the difference is unknown. The IP Mel has developed with his builder has proven far and away a performance improvment and his quality is second to none. DPS's stage 1's trade flow for atomization. This hurts efficiency, starting ease (especially when cold), smoke, and fuel economy. Plus it idles pretty rough as well.
I'm stepping out into the unknown with these. Someone's gotta be the 1st, and they certainly cannot be worse than the only other IDI performance injector option....DPS.
For more Moose injector info.......see THIS POST!
Heath
dyoung14
Is getting worn out
spencer,tn
Heath
yea thats kinda pricey, but if the work good and make good power then there worth every penny of it, i like to see things comming in for idi's
sootman73
Wauseon, OH
thats almost as much as PSD injectors.
stage ones for a PSD are close to $2,000. still a lot cheaper but it looks like were making it to the point of running out of options for enough air for all of this!:dunno
i think someone needs to be trying a twin turbo setup off the manifolds or cummins turbo as other figure out the fueling issues. i would be all over this if i had the know how and money to get it rolling. :(
I'll buy a set,
tho unlike the moose pump, I actually need to know what is done to them.
hell....
as long as they can tell me the volume of fuel is the same with the finer atomization, I don't care what they done to it.
my only problem is, if I run fuel cocktails, I will be ruining a good pump and injectors.-cuss-cuss-cuss
so i I do get the setup, I will have to resist the WMO feedings......
tractorman86
Buckeye, AZ
hell....
same here, i often run wmo blends (filtered and inspected very well might i add) and like that freedom. but if i run a moose pump and/or injectors i dont think mel will stand by it at all will he(cant blame him if he won't)
i won't even go there, warranty issues that is, if I ran anything other than straight #2 with additives that have been OK'd by stadyne(sp) already.
crispy74
