TestDriver
My engine began slowing down on idle a few weeks ago. I turned up the idle stop screw a couple of times but eventually it always slowed way down within a few days. It got to the point where the lever was stopped about an eight of an inch before it would even contact the cold idle solenoid rod when it was energized.
Eventually, it would not even idle and refuses to start without ether even when fully warm and while on straight diesel. Its too cold to risk stopping it on oil right now. When it does start, it'll only stay lit if I keep the throttle about 1/3 open. I can let it drop down almost to the last throttle stop setting but it stalls. When running, it's very smooth and does not smoke. The fuel pressure at the filter outlet is 3psi without the electric pump and 7psi with the Epump while running so I doubt it's a lift issue.
I removed the pump cover and everything looks good and clean inside. The cavity was full of fuel and the linkage moved as expected but I'm not exactly sure what to look for.
Any thoughts?
Any thoughts?
