powder coating injector line
c_silva88
coventry ri
i was wondering if it would be ok if i were to get a set of injector line powdercoated. id like to do it to stop future issues with corrosion.
ah1988ford
florida
You could powder coat everything except the little nipple on the end that goes to the top of the injector, you may also want to make sure you dont put so much powder on that you can not move the "cap" that screws on to the top of the injector up and down.
Idk how hot the lines get at normal operating temp you may want to check that out too, you make want to use the high temp stuff just to be safe.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Also keep in mind that you need a small spot of bare metal right at the nut that threads onto the injector, for the #1 line (or #4 line if you have a van). The bare metal's needed for the timing sensor if you do a pulse-timing...
