FordGuy100
Depending...I think its safer to have studs and boost 10-15psi. The turbo's in the kits start superheating the air around 12psi, so anything past that is not going to get you any gains. You can run more and see more gains if you have a intercooler, but its a good idea to upgrade. Russ has put on 60-1 wheels on them, and his boosts 13psi with his intercooler.
If you want to run more boost, then you have to start looking into other turbo's. OBS PSD turbo's would boost decent, as do DT466 turbo's from what I hear.
Yeah, a 466 international turbo would be a great starting point, seeing as I've got a couple from combines and semis lying around
... im fixing too overhaul my intire truck inside and out she has 258,857 miles and she been to hell and back aleast 5 times but i always maintenance and kept up with her and shes been good....... ill keep oilburners in touch about how the build go`s but first i have to fix the trans to get it to a shop 100 miles away but good luck to you man
