Performance engine parts
FordGuy100
Silverton, OR
Maybe me and Russ can meet up after my engine work and run up to Portland for a few dyno runs.
I'm going to run a torque cam, my pump wide open, wastegate unhooked with 6.0 intercooler, .020" off the pistons, clean up the heads, head studs. I will also make a run with the cold idle advance on to see what the power difference is.
After that, I will look into Moose injectors and a pump of some sort.
I would be happy with 200-225hp and 400-450ft lbs of torque at the wheels when its said and done. Any more than that will be gravy ;Sweet
ameristar1
The One Blue Thing
Steger, Illinois
Did you break down your engine yet?
dyoung14
Is getting worn out
spencer,tn
I thought your new truck only turned 3300rpm's? :D
yea it only turns that high but im about to fix that by either putting a 7.3 pump i got here that is set to 3700 or i will just put a 4000 rpm spring im gettin from mel, but someone is going to have to give me instuctions on how to change springs so i dont fck it up and really mess something up,
FordGuy100
Silverton, OR
Sounds good, make sure you have the intake off and a piece of 2x6" or something to block the intake just incase LOL
dyoung14
Is getting worn out
spencer,tn
if it run away just put it in gear hold the brakes and pop the clutch:sly see how many weak u joints it hasLOL
ameristar1
The One Blue Thing
Steger, Illinois
Hey Justin, I checked out the youtube video of your truck with the busted exhaust. Sounds good. But it looks like you and dyoung are total opposites when it comes to driving style!;p
ameristar1
The One Blue Thing
Steger, Illinois
Why cause im always foot in the floor??:sly
I think I am going to name one of my cams after you. I'll call it the "Leadfoot Special"; goes to 6000rpms, requires twins, an inline pump and complete billet bottom end. You'll be my tester for that one.;p
dyoung14
Is getting worn out
spencer,tn
i would be glad to test it out:sly
