Well, i have notced past few days the slippage is getting worse. even in 2nd gear full boost it starts slipping away and can really reel it in 3rd when boost goes over 20 lbs.
This was a LuK SMF kit, which I did smoke the clutch really bad last summer attempting a sled pull.
Either way its time to replace it. Hoping to get away with just the friction disc but well see upon removal what is really necessary. Truck is probably close to 300 whp. Just street use but will see 8-10k lb towing a few times a year.
I see on roack auto there is an M Pact oragnic steel back clutch which states it is for ownrs towing slightly above rated weight. MPact also makes a ceramic friction disc which is rated for 100-200 horse over stock. Never driven a truck with a ceramic disc-any comments?
I know ceramic can handle more heat and overall has a higher CoF, but thats about it.
