over fueling
jeffgordon24
91 f250 kingcab 4*4
my 91 f 250 has dual frt to back 2 1/4 inch pipes with glass packs . i want to boost the fuel i think there shouldnt be a problem for over heating with this exhaust . and if i put a pyrometer which side would i put it on or should i put 2 lol
thanks jeff
Freight_Train
Traitor to the brotherhood
Gadsden,Al
either side will be fine but if you want to go dual route you can get a wild double Pyro for aircraft engines.Overheating(EGT) can be done with no exhaust so if you even touch that fuel screw you better have a Pyro.
f-two-fiddy
Duluth, Mn.
Do you have a turbo?
If not, your prolly just going to burn more fuel, and not get a lot of gains. Turning the fuel screw is really only worthwhile with a turbo engine.
I know fuel prices are dropping, but still, why watch all that black smoke going out your wallet?
Plan on putting the pyro on the passenger side. The kits come with a lenght of wire, that you don't want to modify, so the passenger side makes the best use of the run.
