Outboard oil in fuel
Mutley
Ontario
Anyone got a fav mix rate for the outboard oil in their fuel? I'm trying to put together my witches brew for the winter and wanted to include that as well. I can't seem to come up with a ratio thru the normal search. cookoo
BleednBlue68
Ford Country!
Eudora, KS
I run super tech tcw3. Works great. Lots of people run that. And its cheap at walmart. I buy the gallon jugs. 1oz per gallon.
Mutley
Ontario
Does anyone know the volume of the two tanks in these trucks? (94.5 PSD CC dually). I made up a witches brew of oil and diesel kleen. It seems to be running fine on it but I'm sure I put too much mix in the fuel. I'll try the 1oz per gal method.
aaklingler
Winfield, PA
I think the front tank is around 17gal and the back tank is around 19gal but I never seem to get that much in, you'll have to watch when you fill up and do the conversions.
