oilcooler torqued
Not really but here is the standard torque for a given bolt size. For a 5/16th bolt its 14 ft lbs and the 3/8th bolt is 24 ft lbs. The front header bolts are 3/8th inch and the rear header bolts are 5/16th inch. I sure don't know why they designed it that-a-way.....
tonkadoctor
none ya bidnes
Torque Spec on the oil cooler headers is 18 ft lbs front and rear on the PSD... but can't find anything in the other diesel manual except the 14 & 24 standard specs as "ICANFIX"ALL stated
