ok we have this over on superdutydiesel.com.i figured it would be useful here as many of you dont venture over there.maybe i can get a mod to make it a sticky.
most of the engine parts are the same for the 99-03.and parts that are 99-up only should also be listed IIRC
This is Joats part number list from his website that is now down. If you have any updates or corrections to the list just post them up and I will correct the list. Thanks go out to tubzz for saving the list before Joats site went down. I cannot guarantee the accuracy of all the numbers, so please before purchasing verify the part numbers. This should only be used as a guideline for ordering/buying parts.
Accelerator Pedal Assembly
See "Throttle Assembly"
AC condensor
NAPA 1K100084
APCM (Auxilliary Idle Controller)
(Ford) F5PZ-12B641-AA
(Ford) F5TF-12B641-AD with LCD display
APCM (Auxilliary Idle Controller) wiring harness
(Ford) XC3Z-14A411-AA
Air Dam
(Ford) F2TZ17626A
(Ford) F2TZ17626B
(Ford) F3TZ17626B (Fiberglass for Ford Lightning)
ACT Air Charge Temp Sensor
(Ford) F5AZ-12A697A (Plastic, in air filter housing)
(Ford) F3VY-12A647-A (Metal, in air filter housing)
Air Cleaner Housing Cover 94-97 F-series (Updated Cover)
(Ford) F6TZ-9661-AB
Air Cleaner Housing Nuts 94-97 F-series (Updated Spring Loaded Steel Nuts)
(Ford) F7TZ-9B680-AA
Air Cleaner Housing Assy 99 F-series
(Ford) F81Z-9600-BA
(Ford) XC3Z-9K635-AA (99.5 F-series--modification kit)
Air Filter (Stock)
(Amsoil) S1968 (2-Stage Oiled Foam, Washable)
(Ford) F5TZ-9601-A
(K&N) E-1946
(Motorcraft) FA-1617 (F-Series)
(Motorcraft) FA-1618 (Econoline)
(Napa) 6417
Air Filter, Open Element (Tymar, Etc)
(Baldwin) PA2818
(Donaldson) B085011
(Fleetguard) AH1141
(K&N) RE-0860 (~12" long w/4" opening)
(Napa) 54-6637 (it seems this doesn't work when looking it up on Napa's website,
but others have said this is the Napa labeled Donaldson and they have to order it)
Air Filter Gauge
(Ford) F7TZ-9N622-AA
Alternator
(Ford) F5UU-10300-CA 215Amp Ambulance alternator
(Motorcraft) GL504RM 130A
Alternator Pully
(Ford) F5UZ-10344-C (8 rib mid 95 and newer)
Antifoaming Additive (counters RTV reaction with oil)
(Fleetrite) CH1824392
(Lubrizol) 888
Auto Hub Lock Grease
(Ford) E1TZ-19590-A
Auto Hub Nut Assembly
(Ford) F6TZ-3N105-BB (retainer nut, retainer key, 3 washers)
Battery Cable, Positive
(Interstate) 2114-001 ($59.95)
(Napa) 717986 (top mount w/Aux Lead, 2/0GA,123" long)
Battery Cable, Negative, Passenger side
(Ford) F5TZ-14301-A
Bed Mount Insulators/Bushings 6 needed
(Ford) E9TZ-5C036-A
Belt
(See Serpentine Belt)
Block Heater w/o Cord
(Ford) F4TZ-6A051-A
Block Heater Cord
(Ford) F4TZ-6B018-B
(Napa) cheaper, dont have P/N
Brake booster ZERO LOSS
(Ford) F5TZ-2005-CA
Brake Master Cylinder Sensor (at the end of MC)
(Ford) F3TZ-9F924-BB (original)
(Ford) 1L1Z-9G652-AA (replacement for recalled switches)
Brake Pads
(Bendix) MDK655FM (fleet grade)
(Ford) XU2Z-2V001-ASA (Autolite with hardware)
Brake Shoes
(Bendix) AF583 (semi-metallic)
Bushings
(Energy Suspension) 4-7110 (radius arm; polyurethane 93-98 2WD F250-F350)
(Energy Suspension) 4-5106 (front sway arm; polyurethane)
(Energy Suspension) 4-5104 (rear sway arm; polyurethane)
(Energy Suspension) 4-4107 (Body mount bushings, 1980-1996)
(Energy Suspension) 4.3121 (2) (Axle Pivot Bushings, 90-96 2WD)
(Energy Suspension) 4.7115 (Track Arm Bushing 85-98 F350 4WD)
(Energy Suspension) See Page (Leaf Spring Bushings)
Bushings, Radius Arm, Plastic insert spacer, not included with Energy Suspension Kits
(Ford) E5TZ-3B244-A (2wd, 2 needed, under $4ea)
Bypass Filter
(Amsoil) BMK11 (base)
(Amsoil) SDF99 (spin-on filter)
(Amsoil) BE100 (replacement filter)
(Permacool) 1216 Fits Amsoil Bypass elements (1x16 thread) Custom, only sold by CJ's 815-625-2031
(Baldwin) OB1305 (base)
(Baldwin) B164 (large filter)
(Baldwin) B50 (smaller filter)
Camshaft Bearings, up to 8/1995, maybe later.
(International) 1812317-C92
Camshaft Position Sensor (CPS)
(Ford) F6TZ-12K073-A 94-96
(Ford) F7TZ-12K073-A 97+
(International) 1821720C99 (below engine 375548)
(International) 1825899C93 (above engine 375548)
(International) 1807339C92 (DT466 CPS, reported to advance timing, and stronger signal)
NAPA CSS1103
Camshaft Position Sensor (CPS) O-Ring
(Ford) F81Z-12B615-BA)
(International) 1824948C1
See "O-Rings" for Individual O-Ring sizes
Camshaft Position Sensor (CPS) shim kit
(International) 1826583C91
Catalytic Converter Delete Pipe
(Ford) F4TZ-5A212V
(Ford) XC2Z-5A212-AA (SD type, cheap but must be shortened)
Clutch
(LuK) 07-154TFW (replacement 12" used w/SMFW; incl. SMFW)
(LuK) 07-127 (12-1/4" clutch replacement)
Clutch Master Cylinder
(Ford) F2TZ-7A543-D (96-97)
Clutch Release Fork (Lever Assembly)
(Ford) E7TZ-7515-A
Clutch, Throwout Bearing
(BCA) FC65662
CMP Sensor
(see Camshaft Position Sensor)
Coil Spring Shim, Height adjusting/leveling, F250 2wd
(Ford) 389117-S2 (service part, washer goes under coil spring)
Column parts;
see steering and shift
Coolant Eye
(John Deere) TY16423
Coolant Filter Base
(Fleetguard) 204163-S Simple base, inlet and outlet opposite each other, $16 at Peterbilt dealers
Coolant Filter (Aftermarket Remote Filter with Spin on, many types)
(Baldwin) B5134 (No SCA) restricted flow
(Fleetguard) WF2077 (No SCA) restricted flow
(Donaldson) P554685 (No SCA)
(hastings) WC8 (No SCA)
(Napa) 4070
(Purolator) PW4451
(Fram) PR3383
(Fleetrite) WFR82077
(AC Delco) WF108
(Wix) 24045
Coolant Filter, for International Water pump with filter
(Fleetguard) WF2071 (with SCA)
(Donaldson) P552071 (with SCA)
(Fleetguard) WF2070 (No SCA)
(Donaldson) P552071 (No SCA)
(Hastings) WC6 (No SCA)
(Nalcool) NF3000 (No SCA)
(Napa) 4020, 4022, 4023, 4026, 4030, 4071, 4072 (interchange, not sure of length fit)
(Purolator) PW283, PW4452, PW4453, W54452, W54453
(Fram) PR3304, PR3908
(AC Delco) WF100, WF113, WF4
Coolant Supplemental Additive
(Fleetguard) DCA5
(Ford) FW-15/FW-16
Coolant Temp Sender
(F1SZ-10884-A (for gauge, mounts on water pump)
(F4TZ-10884-B (for overheat light, RH front of block)
Coolant Test Strips
(Fleetguard) CC6202 (50)
(Fleetguard) CC2602A (four strips)
(Fleetguard) CC2602B (one strip)
Crankcase Breather (CCV) O-Rings
(Ford) F4TZ-6769-A (small; seals screw head; 1/pack)
(Ford) F4TZ-6769-C (large; seals breather adapter to valve cover; 2/pack)
(International) 1824452C2 (Small, 2 needed)
(International) 1820784C2 (large, 3 sided, 2 needed)
Dana 50 TTB Hub Lock Nut Tool
(OTC) 7158
Dana 50 TTB
(Ford) F6TZ-3N105-BB (spindle nut, washer, gasket, autohub bolt, retainer kit)
(Napa) BK1 (spindle bearing, inner & outer seal rebuild kit)
(Napa) 22311 (inner spindle)
(Napa) 711818 (outer spindle)
(Napa) 27452 (hub seals)
(Napa) B2110 (spindle bearings)
(Timken) 382A (wheel bearing; inner race)
(Timken) 387A (wheel bearing; inner bearing)
(Timken) SET38 (wheel bearing; outer bearing w/race)
Dana 50 TTB Wheel Bearings
(BCA) SET A-38
Dana 50 Grease Seal (NAT) 415960
(CR) 27467
Dana 60
(Ford) E0TZ-3C140-B Spindle to knuckle bolt
(Ford) B8TZ-4322-A Spindle to knuckle nut
(Dana/Spicer) 706047X Carrier Bearing/Race
(Dana/Spicer) 706046X Inner Pinion Bearing/Race
(Dana/Spicer) 706045X Outer Pinion Bearing/Race
(Dana/Spicer) 76659-1X left axle assy
(Dana/Spicer) 76659-2X right axle assy
Inner axle seal (updated)...52148...Dana/Spicer
Pinion seal...42449...Dana/Spicer
Spindle bearing & seal kit...700014...Dana/Spicer
Inner spindle grease seal '92-'97...BRS-87...Motorcraft also F2TZ-1S175-CA...Ford
Outer axle stub (30 spline)...49803...Dana/Spicer
Axle U-joints (greaseable)...3-0332...Neapco
-Brake dust shield '94 (may fit earlier years) left...F2TZ-2K005-A... Ford
-Brake dust shield '94 (may fit earlier years) right...F2TZ-2K004-A..Ford
-Trac bar frame bracket...E5TA-3A094-AA...Ford
-4" Blocks...F81A-5598.DB (on block)...Ford
-Rotors '84-'88 '90-'94...BRR-7 (Motorcraft)..YL3Z-1V125-AA (Ford)
-Front leaf spring bushing...4.212G (black)...Energy Suspension
-Trac arm bushing...4.7115G (black)...Energy Suspension
-F350 Sway bar bushing...4.5126G (black)...Energy Suspension
-Rear leaf spring bushing w/ common type bushing (metal outer sleeve)..4.2114G (black)..Energy Suspension
-F250/350 Outer hub bearing/race '94-'97...A-38...BCA/Fed Mog
-F250/350 Inner hub bearing '94-'97...387A...BCA/Fed Mog
-F250/350 Inner hub race '94-'97...382A...BCA/Fed Mog
-F250/350 Inner hub seal '94-'97...415960...National/Fed Mog
STEERING
-F350 driver's side tie rod '94-'96...ES3009R...Moog/Fed Mog
-F350 Pitman arm to tie rod '94-'96...ES3009R...Moog/Fed Mog
-F350 Sleeve (steering components) '94-'96...ES2012S... Moog/Fed Mog
-F350 Pitman arm to passenger side tie rod '94-'96...DS1068... Moog/Fed Mog
-F350 Steering arm to steering arm connecting tie rod '94-'95...DS1071...Moog/Fed Mog
-F350 Upper Ball joint '94-'97...K80026...Moog/Fed Mog
-F350 Lower Ball joint '94-'97...K8607T...Moog/Fed Mog
-F350 0* Camber/Caster bushing '94-'99...K8958...Moog/Fed Mog
DOUBLE CARDAN FRONT DRIVESHAFT
-U-joint C.V. joint greaseable...2-4800HD (Neapco)...5-213X (Spicer)
-U-joint yoke side greaseable...2-4900HD (Neapco)...5-231X (Spicer)
-C.V. centering assy...R2-21-1179...Rockford
Dash Pad
(Ford) F2TZ-1504282-BAD (mocha/tan)
(Ford) F4TZ-1504282-AAY (light grey)
Dash repair kit for right (passenger's) side dash mount. Frequently get broken.
(Ford) F4TZ-1504366-A
Daytime Running Lights Module (Check Ebay, they are often pulled off Canadian wrecks and auctioned)
(Ford) F43Z-15A272-A
Door Latch
(Ford) F2TZ-1521813-A
Door Darts (Inside Panel Push Fasteners) (also available at almost any parts store)
(Ford) N802900-S
Door Inside Panel
(Ford) F4TZ-1523943-BAD (mocha/tan)
Door panel light (clear lense)
(Ford)F2TZ-13734-B (Driver's side )
Door Weatherstrip, Drivers side inside belt molding, Felt strip inside that window rubs against
(Ford) F2TZ-1521457-A
Dipstick part numbers: (If yours is stamped 1820068C1, REPLACE IT!, it reads 2 qts too low!!!)
(Ford) F4TZ-6750-E (F-Series)
(Navistar) 1824405C1
(Econoline) F5UZ-6750-A
Dipstick Mount Seal Repair Kit with instructions
(International) 1846146c91 (silicone, loctite gasket eliminator, adapter gasket, dipstick oring
Dipstick Tube O-Ring
(International) 875519C1
see "O-Rings" for standard sizes
Dual Idler Mod
Engine Belt
Engine Cover, Front
See "Timing Cover; Front "
Engine Top Cover Bracket/Mount
(Ford) F81Z-6A955-AA or YC3Z-6A955-AA (mount for 97-up shorty cover)
Engine Top Cover Nuts
(Ford) N800475S101
Engine Oil Temp Sensor (EOT)
See "Oil Temp Sensor"
Engine Oil Pressure Sensor (EOP)
See "Oil Pressure Sensor"
Engine, Shortblock
(International) 2504315c91 96-97
Exhaust Back Pressure Regulator (EPR solenoid; up to 98.5)
(Ford) F5TZ-6C673-A
Exhaust Back Pressure Regulator Valve EBPV
(Ford) (old F4TZ-9J460-A) (new 1C3Z-9J460-AA) (94-96; mounts on bracket above oil reservoir)
(Ford) F7TZ-9J640-AA (97-up; may mount like earlier models, later in front of reservoir)
Exhaust Back Pressure Regulator Valve Tube
(Ford) F4TZ-9D477-A
Exhaust Back Pressure Regulator EPR solenoid, up to 98.5
(Ford) F5TZ-6C673-A
Exhaust Back Pressure sensor
(Ford) 1C3Z-9J460-A (94-96; Mounts on bracket above oil reservoir)
(Ford) F7TZ-9J640-AA (97, mounts like earlier models; 98 and up, mounts in front of reservoir
Exhaust Back Pressure Sensor Connector
(International) 2501105c1 (also ICP Connector)
Exhaust BackPressure Valve Actuator Seal Repair Kit
(Ford) 2C3Z-9P466-BA (94.5-97)
(Ford) 2C3Z-9P466-AA (98-02)
Exhaust Brake
(BD) 2033143
(Pacbrake) C15000
Exhaust Collector Donut
(see turbo Exhaust Collector Donut)
Exhaust Manifold to Head Bolts (flanged bolt with special prevailing torque threads)
(Ford) F4TZ-9S425-A
Exhaust Manifold Gasket
(NAPA) MS-16314
Exhaust, Turbine Down Pipe
(BD) 1047310
Fan Belt;
see serpentine belt
Flexplate Crankcase spacer (94-99)
(Ford) F81Z-6A366-AA
Flexplate Engine Spacer (94-99)
(Ford) F4TZ-6A369-A
Flexplate Reinforcement Plate (94-99)
(Ford) F4TZ-6A366-A
Flywheel, Dual Mass
(Ford)F-7TZ-6477-DA
AC condensor
NAPA 1K100084
Air Dam
(Ford) F2TZ17626A
(Ford) F2TZ17626B
(Ford) F6TZ-9661-AB
(Ford) F81Z-9600-BA
Air Filter (Stock)
(Ford) F5TZ-9601-A
(K&N) E-1946
(Napa) 6417
(Baldwin) PA2818
(Donaldson) B085011
(Fleetguard) AH1141
Air Filter Gauge
Alternator
Alternator Pully
(Lubrizol) 888
(Ford) E1TZ-19590-A
(Ford) F5TZ-14301-A
(Ford) E9TZ-5C036-A
Belt
(Ford) F4TZ-6A051-A
Block Heater Cord
(Ford) F4TZ-6B018-B
(Ford) F5TZ-2005-CA
Brake Pads
Brake Shoes
Bushings
Bypass Filter
NAPA CSS1103
(Ford) F4TZ-5A212V
Clutch
(Ford) E7TZ-7515-A
(BCA) FC65662
CMP Sensor
Column parts;
Coolant Eye
Coolant Filter Base
(Napa) 4070
(Purolator) PW4451
(Fram) PR3383
(AC Delco) WF108
(Wix) 24045
(Fleetguard) DCA5
(Ford) FW-15/FW-16
Coolant Temp Sender
Coolant Test Strips
(OTC) 7158
Dana 50 TTB
(BCA) SET A-38
(CR) 27467
Dana 60
STEERING
Dash Pad
Door Latch
(Ford) N802900-S
Door Inside Panel
Dual Idler Mod
Engine Belt
Engine Cover, Front
(Ford) N800475S101
Engine, Shortblock
(Ford) F5TZ-6C673-A
(Ford) F4TZ-9D477-A
(Ford) F5TZ-6C673-A
Exhaust Brake
(BD) 2033143
(Pacbrake) C15000
(Ford) F4TZ-9S425-A
(NAPA) MS-16314
(BD) 1047310
Fan Belt;
see serpentine belt
(Ford) F4TZ-6A369-A
(Ford) F4TZ-6A366-A
Flywheel, Dual Mass
(Ford)F-7TZ-6477-DA
