now whats wrong?
scheid6996
scheid6996
well now at like 1300-1500 rpm my truck surges, and i thought it was the fuel filter, so i changed it, but it didnt really make it any better, and i want to adjust my fuel pressure, i have a gade but i cant find a shrader valve anywhere, napa and shucks both say they cant get it, any one have any ideas, i have the tool, but no fitting
scheid6996
scheid6996
hmm ya i kinda thought that, but wasnt sure, thanks, well that artical shows that his gage has the right fitting, but mine doesnt, so i was tryen to see where to get one
Colorada
The fitting is on the back side of the fuel filter canister on the drivers side of it. I takes a Boss o-Ring style fitting and I think it is a 6 but dont qoute me on that. Then you just need a Pressure gauge that can be hooked to that type of fitting some way. Preferably Liquid filled gauge. If you have a Parker Hose store around you they can fix you up.
Double-S-Diesel
parts seller
derry pa
another option for reading fuel pressure is remove the plug in the pass side front of the head, put a 45 degree street elboe in there, and a schrader vale adaptor in. then leave it there for future use, this is what I do on customers trucks when needed.
scheid6996
scheid6996
but i cant find a shradervalve anywhere, thats my problem, and now the pulsating is getting worse
scheid6996
scheid6996
ok, i found a fitting and checked my pressure, it was about 60, i put a bb in, and it went to 100, i didnt have enough time to remove the bb so its still in there, ill take it out soon tho, but i unloaded my evolution and it stoped surgging around 1500rpm, and the hight the level 1-2-3 the whorse the surging, but i put it back to stock and it stoped, what does it sound like the problem could be?
Mike
Stroker
Cora
Dont run your fuel pressure at 100 psi, your pump die a quick but ugly death.
scheid6996
scheid6996
i didnt have time to change it, ill change it back as soon as i can, i had to go to work, i plab on changing it today when i wake up, im working night shifts now, it sucks
scheid6996
scheid6996
ok so got it turned back down to 70 psi now, but i still cant figure out why the evolution whould make it pulsate around 1500
