Where are all the orings that I am going to have to replace?
Where can I get that Nylog stuff at and how do I use it?
How is this variable orifice valve used?
You will have an oring at each joint in the hoses and one at the quick coupler before the orifice tube ( which you will likely need a spring lock tool to open up depending on year, a couple of bucks at the parts store ) True, orings saturated with r12 mineral oil in service will usually hold, but on aged systems or ones that have been sitting without mineral oil regularly circulating on them, you can pretty well count on them being bad. You will need to replace them.
You can get
Nylog here get the blue for use with PAG and Ester systems Coat the new orings with it to lubricate the ring for instalation and seal the joint.
A variable orifice valve is used in place of the factory fixed orifice tube ( which you need to replace anyway ) it adjusts the size of the hole and makes for much cooler duct temps, you can get them at advance etc, I can get a part number if needed. they run about $30-35 , but they're worth it. I stick them in every system I open.
If the old comp seized up, you definitely need to flush the system . Seperate all of the fittings, remove the condenser and lay it flat, get a quart of ac flush and you can pour it through, but a cheap siphon gun from Harbour freight works great to spray the stuff through , then let it sit a bit and blow out with rubber tipped blow gun. Flush all componants till they run clean An air drier on the shop air is strongly recomended to cut down on the time needed running the vacuum pump, as it is, really should let it run overnight after flushing and re assembling unles you have a real stout vacuum pump
You should be able to adjust the screw on the back of the pressure switch to cut out at a lower pressure , around 20 -22psi for the R134a this will make it colder
