No fuel to injectors...
darwin
Boise, ID
I am not getting any fuel to my injectors. I checked the output pre IP and I get fuel, but after the IP i am not getting anything. What could be the problem? My only guess is I have a bad IP. I have checked the IP solenoid, the i pulled the cover facing the radiator and the shaft turns on the IP, but still no fuel. Could the shaft on the IP be sheared? I am clueless here what could be the problem.
Truck is a 92 7.3 mechanical lift pump.
