New single disk clutch kit 7.3 diesel/ZF5
philofab
Dirty ****
Bullhead, AZ
The ZF is a 6.9/7.3 pattern? What other stuff do you have to go with it? I am converting my truck to 4x4.
AZBLACKSMOKE
no truck payment
Safford,Arizona
Yes, its on a 7.3 diesel engine now. I have the engine, ZF5, transfer case, crossmember, driveshafts for a ext cab long bed, shifters, stock flywheel, clutch, and pressure plate. But the Flywheel was making noise, so I do not recommend using it.
Everything otherwise is in great shape. 180,000 miles. Well maintained.
Make me an offer.
Oh, and I have the frame of the truck with rolling axles...3:55 ratio.
I can deliver too for a small fee or meet you somewhere. Ill post a picture of everything I have shortly.
Thanks.
philofab
Dirty ****
Bullhead, AZ
Make me an offer.
Thanks.
Awesome. Flywheel will not work for me as my truck has a 6BT in it. Looking to upgrade from my current C6/GV combo, and you have all the parts I need. You are about 400 miles away from me. Do you ever go to Phoenix?
I would want the trans, clutch, t-case, drivelines, shifters, and maybe the axles.
The the rear a Sterling? Is it posi (denoted by L on the tag)? Front a D44HD or Dana 50? T-case a manual 1356?
AZBLACKSMOKE
no truck payment
Safford,Arizona
Yes. I go to Phoenix once in a while.
The rear is a Sterling, not sure if the tag is an L. The cab is gone, but Ill see if theres a tag on the pumpkin? Its a D44HDas far as I know and manual T-case.
Im on my way home in 25 min. Ill stop by my shop and snap some pics for you and you can give me a call if you want.
928-965-3644
Thanks, Jared
AZBLACKSMOKE
no truck payment
Safford,Arizona
Heres some pictures of what I have left.
1990 F250.
Its basically a rolling chassis.Ext cab long bed 4x4, Engine is complete. NA 7.3, runs but runs very rough. I think the IP is shot. Frame, steering box, steering from pitman arm down, front 44HD(i think)complete minus lockouts, sterling rear, no LS tag, 3:55 ratio, S42 ZF5 speed, BW transfer case, Shifters(not pictured), rims, tires, fuel tanks,etc.
If its not pictured, let me know, I may have it.
AZBLACKSMOKE
no truck payment
Safford,Arizona
Hmm. Whats up with *** on this forum? Got the email.
I dont think you have turned them on in your user settings because it gives me no option to send you one. But thats ok, email works. I was just letting you know your private messaging wasnt available. ;Sweet
opusd2
BFE, WI
It's times like this that I wish I'd live closer to the deals.
Vincent
