New from arkansas and tired of the gas scene!
danos81chevy
US
I have a 1991 ford f150 scsb 4x4. I have been researching about going carbureted on then said forget carbs and ive decided to do what i really want. Drop a diesel in it. Now before people get into frame and axle strength drama. Its getting boxed and sas with 1 tons.
danos81chevy
US
Heres how she sits
cpdenton
Truck needs paint.
Conway AR
Welcome. Where in arkansas, and what kind of diesel?
danos81chevy
US
Im in widener right now but moving to fortsmith in about a week. And im thinking 6.9 idi with some internal work and a turbo. Nothing record breaking but enough to keep up with stock powerstrokes and some cummins.
the hardest part about this swap is the driverside engine mount.
maybe the trans X member.
and wiring.
other than that youll be ok until you kill the bearings in the front end due to weight.
theres a few guys that have done this.
search F150 in the IDI section.
welcome to OB
danos81chevy
US
I dont have to worry about the front end. Itd be getting 1 tons. And the mounts and wiring should swap right over
the wiring out of a diesel truck will swap,
switching to a diesel cluster and FSV will be needed if you want everything to work.
the frame on the F150 is different than the diesel 3/4 or 1 ton.
you have a hole in the driverside for the oil filter.
but youll find all of this out.
danos81chevy
US
Yes i know i will need to adress the hole in the frame but thats easy work. I planned on buying a doner truck using the dash components and using a bronco 38 gallon rear tank. (Mines a factory rear only tank) and using the harness and engine and trans out of the doner. As well as a dana 60 and 10.25 axle with a 1in body lift. And to weld in some boxing plates along the frame.
danos81chevy
US
Ive been looking at that thread haha. I know what its going to take to do it. Im just saving up for a donor truck. Hopefully one i can pull the dash and interior out of. Mines crap.
