need TC help!!!
Nickbf2504x4
ATV Racr-IDI Driver
Colorado State!
just got my front gears swapped and now have 3.55's at both ends...put her in 4x4 and she didnt want to go into low range. rocked the handle back and forth and got it in...now no matter what position of the handle my truck stays in low...could i just be low on fluid? i hope! goimg camping tommorow hopefully!
where do i add tc fluid?
just ATF? is that what i need? thanks
PS
emergency is that im 50 miles from home and can only do 30 mph! :mad:
jlayne
Bondo Bandito
Milledgeville, GA
incase you are still stuck
sounds like to me you are having some linkage/shifting fork issues, are the front wheels pulling all the time? or is it just stuck in low range?
crawl under it and make sure your shifter is still hooked to both the shafts that come out of the Tcase... you might get luck and it just sheared a pin off
if everything is still hooked properly and the linkage isn't bent or broken, :eek: i'm gonna say it has broken a shifting fork and will have to be cracked open to fix it
