More Plow Plug Help- its that season
m67tang
lawrenceburg IN
I am taking out the fuse-able links behind the passenger side battery. Then installing a fuse block. I need to know the amperage of the glow plug supply wire so I put in heavy enough wire, and a fuse that will support the GP's. I have looked at other threads but not found this info.
Its the truck in my signature.
Each glow plug will suck up 20 amps when first starting to glow for about 2 to3 seconds, then reduces to around 3 to 5amps for a 15 second cycle, providing you have the zig zag Chromolox strip still there, that protects the wiring from inrush current which could be over 200 amps total. Fuse to use, 100 amp rating, they are expensive, or similar. Holder is a bolt down tab. http://www.ferrazfuses.com/cms_admi...anager/connectors/php/bin/GP Class L A4BQ.pdf
m67tang
lawrenceburg IN
wow- I did not think the current wire size was that heavy!
So what size wire will support 200 amps. I had bad fuse links to begin with so here I am now. Wish I could avoid this altogether.
m67tang
lawrenceburg IN
does more than 1 wire feed to the glow plugs at this point? ( links behind the passenger battery)?
I edited my previous post, look back. There are 2 conductors (tan or yellow color) fusible links to the GP relay power. Google fusible link wire, then you will understand it's a special kind of wire.
crewchief219
Wichita, KS
I used a 250 amp fuse. I attached the fuse to a starter relay post, and ran a 4 gauge battery cable from the fuse to my controller. Its been working great.
m67tang
lawrenceburg IN
I had not studied this before, So I had no idea how much amperage was involved. I might be better to go back to 2 separate 10ga wires with 14ga fusible links. That is the factory OEM way.
Or the way you have it will work too!
crewchief219
Wichita, KS
I got my fuse from ebay. I don't see the exact one I bought, but the link below is the same style. Like I said, I attached the fuse to starter relay post and then attached the battery cable to it. I got the 4 foot, 4 gauge battery cable from Oreilly's, it was relatively cheap and wound up a perfect fit, didn't have to modify it or attach any connectors, just bolt it all together. I can't find a link for that. It was just something they had on the shelf in the store. Hope this helps.
http://www.ebay.com/itm/ANL-250A-Car-Audio-Gold-Plated-High-Quality-Inline-Wafer-250-Amp-Fuse-2-Pieces-/171053500209
Here are a bunch of other fuse options..
http://www.ebay.com/bhp/250-amp-fuse
crewchief219
Wichita, KS
Yeah, it's definitely not OEM style.. lol.. but it's been mentioned recently in some other recent posts that the factory wires work well when they're new and will eventually overheat as the cables age. They're not really sufficient for the amount of power that the glow plugs draw. Replacing the factory parts or using the same style will work, but eventually you run the risk of smoking the 8 guage cables, which is what happened to me. That's why I went with one 4 gauge.
m67tang
lawrenceburg IN
I am learning a lot here. Glad this website exists!
My trouble began with being mis- informed by a Ford technician. So now I get to keep working till it's fixed.
m67tang
lawrenceburg IN
Did you find a fuse holder for the 250 amp fuse ?
m67tang
lawrenceburg IN
I just picked up 5' of 4ga battery cable. I like the 250 amp breaker on fleabay better than using a fuse.
My stupid question is: does it really take 250 amp for the glow plugs?
Even at 20 amp each it's only 160 amp total.
I just don't wanna catch something on fire.
crewchief219
Wichita, KS
m67tang
lawrenceburg IN
Having now read your thread I am gaining a lot more knowledge of what is going on with my truck. The slow blow fuse is a new concept to me. It's a real learning experience. Great to know this since I have an IDI and so does my Dad, and brother too.
m2rtin
