I think the Moosestang may have developed what I'm hoping is a torque converter problem, and it's sidelined at the moment by this. What I get (which developed all of the sudden it seems) is a violent chatter similar to a bad manual clutch on acceleration in all gears, and it persists slightly under any load. Coasting or decel is fine. I know it's not an engine miss. The steering column and the whole front end gets to hammering pretty bad, so I'm letting it sit until I have time to work on it. The reason I suspect the TC, is it was custom built, and is a low stall design that probably is not something the outfit that built it has a lot of experience with. I can envision what would happen if one of those fins inside lost a weld and folded back or something. What do you guys think?
