Talk about frustration...........
In trying to shake down my high RPM fuel delivery issues, I decided to go ahead and replace the mechanical fuel pump. It appeared to be the factory original as it still had the International grey paint all over it.....
Well I removed the damn thing and called my local NAPA. The one they had has a very different looking pump lever than the one my truck had. The NAPA one was about 3/4" longer and just some mild bends - almost a straight upward lever. The orig. unit I removed has quite a significant pair of bends making it look like an "S" in a sense.
The first NAPA pulled up their photo of the pump and by part number, it showed the pump should look exactly like my original one... they said the pump in their box was mis-packaged so they called two other stores - they described the lever and both said "Yeah, ours has the sharper "S" bends in the lever............. I get to those stores and it's the same damn one as the first.
Advance Auto showed two on their computers - one was the wrong lever and the other was a Bosch unit with the correct lever, but they can no longer get it.
I stooped to go to Checker Auto and they too only had the longer, straighter lever pump.
Did Ford do a re-design of the fuel pump? Could the straight lever be correct? To me, looking at the pumps side-by-side, I don't see how the cam lobe would correctly contact the straight lever pumps......
I'm pretty unhappy....... and I have a busted, immobile truck in my driveway........ at least until I put the old pump back on and figure out how to find it's replacement.
Also, am I going to have problems with air in the lines since it'll be sitting with out being connected to a pump for a day or two?
As always, thanks in advance!
