akoldnav
I needed to do a front brake job on my 90 F350 C 4X4. When I got the wheel and Caliper off I discovered a cracked roter. I pulled out the guts of the manual locking hub assembly (Had to to get to the nuts that hold the hub on) which came out a little hard. Now when I am trying to put it back together, the large splined aluminum piece will not go back into the hub.
Would putting a little heat onto the steel hub and placing the aluminum part in the freezer help, or do I have some problem that requires a complete replacement of the manual locking hub parts?
Thanks
akoldnav
Thanks
akoldnav
