DieselChemist
This just started developing last week. Whenever I seem to turn the truck, even slightly ( like a curve in a road) the oil pressure changes alot it will go from N to where the line is on the low end of the gauge. No change in rpm or speed. And I'm talking just a slight curve will do this. I also noticed the oil pressure on the gauge at idle will change if I am slightly nose up or down. I am only 1 quart low on oil. What concerns me is going around a curve today the oil pressure went so low it kicked the engine light on. I know the Ford gauges are bad but is this the downfall of a oil pump or is it just the gauge. The truck has no oil leaks.
Thanks
Bill
Thanks
Bill
