IDIDieselJohn
0-60....eventually
Looking at this 1986 F350 2wheel drive 6.9 diesel, everything is good about it, runs great drives great, but When you start the engine cold, fire off instently but has a little shake, nothing bad though (that's on high idle) onces the high idle kicks off, it starts shaking even more. Sounds perfect, smooth idle sound, but visually shaking, if you rev it past 1000RPM it stops. Went for drive, abit of stop and go, then hit the highway, everything is A1. When we got back, was idling the same but very smooth, not shaking at all. Guy said it has new injectors, IP pump, lift pump and updated glow plug system on it all from within the last 3 years. He said it's been shaking like that for over a year, but after you take it for a drive it stops doing it. I don't get it what the hell could it be, runs and sounds perfect!
Edit: Engine shakes on low idle after cold start up, after a drive idles perfectlly smooth. Sound doesn't change. No smoke of any colour, only black smoke when you put your foot in it.
Truck specs: 1986 F350 stock 6.9 Diesel 2 wheel drive, C6 transmission, 140,000 miles (3.55 gears not sure though) been used to haul a 30ft. fifth wheel for over 12 years.
Any thaughs appriciated
