Lift pumps for the truck
subway
be nice to the admin :D
York PA
info on the a-zone pump
About this product:
Part Number: E8012S
Weight: 1.5 lbs.
Warranty: 1 YR
Application: With vent tube
Note: Universal
12 volt 5 to 9 pounds of pressure *** Caution *** installation requires the fuel pump to be wired through an oil pressure switch. For installation tips or questions, please call: **** 1-800-424-7839 ****
Pricing:
$35.99
Availability:
Store: Normally stocked at your local store.
Online: Ships within 2 business days
for the price i might try one out and see how it does.....
69dieselfreak
well that nice
rimrock arizona
About this product:
Part Number: E8012S
Weight: 1.5 lbs.
Warranty: 1 YR
Note: Universal
Pricing:
$35.99
Availability:
thanks ya that would be some thing to try out for that price
Airtex E8153 is rated for pushing the heavier fuels at 11-15psi. Not cheap though. About $70. I have one pushing my WMO through the filters.
subway
York PA
thats still not bad for a price and interestingly looks the same as the a-zone pump. so where can you get the airtex stuff from, i didnt see a dealer locater on there site?
actaully now that i compare it looks eerily familiar
the airtex is the top one and tha a-zone one being the other
subway
York PA
update i decided to check out the one at a-zone and guess what:D
they are the same;Sweet i will try to get this system together and see how it works soon!
460429_freak
Crazy about diesels
mo
I've only got 2 years out of them pumps picture and that was on my gasser's ....
69dieselfreak
well that nice
rimrock arizona
are u going to run with ur mechanical lift pump also or what is ur set up going to be
subway
York PA
right now i am planning on running a tank in my bed and i mounted the pump inside the frame rail right on front of the bed. the pump will be for the tank bed only since i didnt know how to use the stock lift pump for a third tank without a bunch of fuel relays. this way i should only need two relays, one for the injection pump intake and one for the return lines. my third tank bed would then be on its own pump and filter system.
Nanohawk
