Let down by the blue oval...
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
Ummm, what? :dunno And why were you barehanded with no coat? Glad you got it sorted out though.
There isn't enough work to keep me going a full week, so what happens is I get a day or two of work, and that is just enough to keep me from getting E.I. I worked just before Christmas, one or two days last week and I was supposed to work yesterday and today....but the hoist packed it in on the old Louisville....:rolleyes:..never fails!
I'm just trying to figure out why he has one under his hood to power his ip?
The PO had a wiring NIGHTMARE done to this thing when I got it. GP's came on with the key...when they wanted to, IP was on a toggle switch and the timing advance/high idle was non existant.
I dropped a constant duty solenoid in, ran a trigger wire and used all that to power up a mini fuse panel under the hood. My 4 - 100 watt back up lights, FSS, high idle and advance run off it, the GP's, run off it, the CB radio is tapped into it and I can't remember what else. Just a little homebrew to keep my truck a little easier to work on under the hood.
Yes.... He has done some cleanup from the PO of his truck.... he has mounted a fuse panel on the inner fender and runs everything from it.. his ele fuel pump, GP's IP and other things from it.. and it has a constant duty solenoid so it does not receive power when the "ignition" is off..... I remember him talking about this in another thread......
Exactly! Saved a pile of headaches!
tke395
