junk E4OD
rancherman84
P.E.R.F.E.C.T!
clyde NY
anybody got a junk E4OD for an IDI?
i am thinking about building my own y-pipe for my banks turbo.
i have the 7.3 that i pulled from the 89 that i parted out,and if i could find a E4OD to mount on the back i could fab the piping on the shop floor then mount it on my truck.
i dont really care if it has a cracked case or whatever,i think i just need a basic housing to fab around.
will a gas tranny even fit close enough to work with?even if i had to drill some holes?
gasser big block will bolt up on the lower four holes. the upper two will have issues. hope this helps
NJKen
is a daddy!
Central NJ
If you have anyone in your neck of the woods that does serious truck fabrication work they may have a fiberglass dummy trans case for just that purpose. Summit racing used to sell them for about $100. I am not sure they still do though.
Just a thought
Ken
rancherman84
P.E.R.F.E.C.T!
clyde NY
i have seen those fiberglaas mockups before on horsepower or some other show.just thought they wernt cheap.anybody gots a summit or maybe jegs catalog they could check out for me?guess i could use this thing they call the internet huh :confused: :D
as for them all being junk,i am on the same page as OG at this point,its not the tranny that is junk its the factory controller.
NJKen
is a daddy!
Central NJ
Even getting a junk one is gonna cost some $$$. Another thought I had is check with your local trans rebuilder and see if they have a junk case laying around. When the early E4OD's crapped out they can wipe out a case (mine did). It could be worth a try.
Ken
Seven4eight
