Jasper 7.3 IDI?
snicklas
6.0 and Loving It!!
Staff member
Administrator Moderator
Greenfield, Indiana
Sorry for the brief hijack, but will someone clarify something for me; are you saying there are normal 6.9 controllers that screw in the head and use the existing harness, that are no longer prone to failing and taking out the glow plugs? If so, which controller would I need? That would be a simple and relatively inexpensive upgrade.
Yes,
Here is a link to the thread that Mel made about the controller:
http://www.oilburners.net/forums/sh...ighlight=6.9+Glow+plug+controller+solid+state
It came from Accurate Diesel according to the article.
pastorjeep
Gatesville NC
Mel. I didn't know about the updated 6.9 controller, but my 84 has the 7.3 style controller. I did notice that my harness connector and the one from the 93 van the engine came out of are different. While I was pulling the engine out of the van in the JY I found another 7.3 that had a new controller and I grabbed that as well. I'll post pictures of the different harness ends.
pastorjeep
Gatesville NC
Need some help and after searching the site couldn't find what I need. I am losing prime after only thirty minutes of sitting. I have eliminated all external leaks. a friend believes it is my FSV that recently started drawing from both tanks and not sure which one it is returning to. Could a bad FSV cause a fuel drainback? I have to crank for about 10-15 sec to get fuel up and once I get it there is no missing like air in the lines, runs fine? The engine itself runs great, plenty of power. Really happy with this find.
laserjock
Almost there...
A tip for searching the site. Don't use the search function. Some people have great luck with it. I'm not one of those people. Use google and type what you are looking for and then add "site:eek:ilburners.net" without the quotes.
Another suggestion is don't be afraid to start a new thread for a new problem. You are much more likely to get more and better info.
As to your problem, leaking FSV can cause problems. A more likely scenario is that your fuel line olives are bad if your return lines are good. Typically that will cause a start and die condition though. If you know the FSV is bad, I'd either change it or bypass it to troubleshoot. If that solves the problem then you decide what to do as far as repair or replacing with manual valves.
pastorjeep
Gatesville NC
I was willing to live with drinking from two tanks at once, but if its causing hard starts i will bite the bullet and put a new one on ;)
laserjock
Almost there...
If it's drinking from two tanks at once that's not good. They sometimes stick one way or the other because pieces of shower head get stuck in them. Oldbull8 pretty much has the definitive thread on FSVs. They can sometimes be fixed. Search for it on here.
