Instrument cluster grounds?
SLC97SR5
UT
My factory oil psi gauge has started to flick around and pulse with the vibration of the engine.
I have replaced the oil psi sender and cleaned up the pig tail connector. I think a ground is at fault.
I polished up the frame to cab ground strap on the passenger side as well as the EEC test connector ground and the 2 grounds under the hood near the passenger head light.
Where are the grounds for the gauge cluster?
Thanks!
Get a real gauge. Only true way to fix it. The factory one is a dummy gauge. It comes up at 7 psi and that's it.
SLC97SR5
UT
I'm aware that they are not true reading gauges but the pulsing irritates me.
cpdenton
Truck needs paint.
Conway AR
Grounds are located behind the drivers side kick panel. Also, might need to clean the contacts on the rear of the instruments themselves.
ifrythings
BC
Don't forget to check the main engine plug on the lower drivers side of the engine, it's not a sealed plug and can be causing your issue.
FarmerFrank
Blairsville, Pa
The push-in pins gets loose and worn on the back of the gauges to the instrument cluster from vibrations. I had an 88' do the same thing and turned out to be them. If you know what I'm talking about
Bradz
