My factory oil psi gauge has started to flick around and pulse with the vibration of the engine.
I have replaced the oil psi sender and cleaned up the pig tail connector. I think a ground is at fault.
I polished up the frame to cab ground strap on the passenger side as well as the EEC test connector ground and the 2 grounds under the hood near the passenger head light.
Where are the grounds for the gauge cluster?
Thanks!
Thanks!
