Rusty Rig
Hi guys. Let me first start off by saying that I am new to this forum, not only that but I'm new to forums altogether. I am not sure of the etiquette when posting something. I'm sure my question has been asked before but I just don't know forums well enough to find the answer or even phrase the question I have. That being said. I have an 85 F250 6.9idi. I acquired the truck a few months ago and since then have installed: a new mechanical pump, return line, and coupling kit and new fuel filter. One of my tanks was rusted through so both the return line and supply hard nylon lines were sealed and capped off. I have clear fuel coming from the filter housing Schraeder valve with no air or bubbles at all. My problem is that the truck will not start after its been sitting. I have attempted to bleed the injectors several times but when I crack each B-Nut I barely get fuel. Mostly just light spitting of fuel and air. I had fuel leaks before but all of those have been fixed. I've had a 6.9 before and I know I should get way more fuel at the injectors than what I'm getting. The truck may have 140K on it total. Any suggestions? Injector pump rebuild time or what?
