justinray
Contributor
Would it be a problem if I mounted an in bed fuel tank and ran the 'front tank' lines to it? I haven't had a front tank since I bought the truck, but the switch works, and the lines are still there?
Stock pump is blow the tanks. My carter mounted on the fender has no issues and runs the same as if it were mounted lower. When I was running a thicker mix of WMO it would lack flow at higher RPM just like my 93 with the stock lift pump and tank set-up. The pump still has to pull the fuel up the sending unit and push it up through a filter to the engine.
How do you know your pump was cavitating and the high fuel tank was the issue??
Even if you pulled off the line and let it gravity feed it's only flowing like 5 GPH. I was draining a tank like this before and it was taking forever to fill a 5 gallon container.
ahhhhh, the voice,, of EXPERIENCE speaks.........and travis reiterated it........He doesnt have a stock pump , or a carter electric that is designed to almost require itself to need a siphon effect by being mounted below the fuel tank. . if you read the OPs signature , he has a facet Dura lift, and that thing is designed to be mounted ABOVE the fuel tank, especially when you run into a situation like a large bed tank that gets WAY up there, the dura lift will stop pumping. These things were designed to be mounted way up high in teh engine compartment of a refrigeration unit on a refrigerated transport trailer and draw fuel from way down under neath the thing from the fuel tank down by the dolley gear, and they were designed to run 24 hours a day , 7 days a week. They are fabulous pumps, but you HAVE to mount them in the manner that they were intended,
They can handle a lateral flow like from the stock rear tank mounted in between teh frame rail to the pump mounted high on the frame rail without issue, but to take teh same pump and hook it to a tank mounted way up in the bed , forget it. Ive already been down that path and it took a while working with the factory engineers to figure out what the problem was, considering that I was one of teh first folks to use these things in non commercial applications, they hadnt experienced teh problem before and had to do some digging to figure it out, but they were very diligent and chased down the problem.
