IDI Towing
Macrobb
North Idaho
See if you can source a IDIT fan clutch. The turbo-model fan clutch is different. It engages at a much lower temperature.
(I've had it engage during the summer with water temps in the 205F range).
OP- sorry for the thread jacking!
So that would seem to be correct. RA lists the motorcraft clutch for a 91 NA but not for the 93 turbo or NA. But the same Hayden clutch is listed for both as “severe duty”. Interesting.
Cubey
Van dweller
If you expect 14mpg empty, you must get a truck with a overdrive trans.
I get around 14 hwy with my slightly tall, insulated camper shell, full of stuff, with a C6. Its RWD, but still. (See avatar pic)
I got about 8 city/10 hwy pulling a 27ft travel trailer, plus the camper on the bed.
placidoert
