93turbo_animal
Do you mean 5th wheel or Goose neck? 5th wheels can be a pain like Mel said in uneven terrain and hooking back up if not pefectly level can cause quit the problems
912504x4 said:Anybody know if I can tow a 36 foot goose neck enclosed trailer behind my IDI for an extended period of time at highway speeds or will she overheat on me?
With lets say 5xxx lbs in the trailer and the trailer weighing in at 32xx lbs empty. 8000-8700 payload + 7500 lb truck
Or better yet how much can I tow for extended periods at 65 mph.
I say 65 because in Missouri where I frequently go wheeling there is a good stretch of 70 mph zone and I don't wanna get run over.
There will be some hills also. These are not rockies for sure but enough to slow me down a bit last trip out there (before stick shift conversion).
Just a thought. I have found several of the longer trailers just above my price range but much better equiped for the money.
Call me crazy if I am.
Thanks, Eric
tuckerd1 said:I'm with Lucky here. I tow a 33' 5'er that weighs in at ~ 12000# wet. Highway speeds run 60-70 with no overheating problems. I'm running NA rite now so the long hills suck towing that much weight. Turbo to come soon!
Mikes91 said:I wanna know how you're pulling that much weight so faast with no turbo.
I'm running a turbo and I can only now cruise at 70-80 with 10,000 pounds in tow (30' horse trailer). Little hills don't seem to matter, but big'uns will slow the truck way down with that load. Turbo'd, new pump, new injectors.
Maybe I should just rebuild the engine??
When the truck was N/A... I had to draft semis to go 65.
Mike
Mike
Mike
tuckerd1 said:When I'm on the road towing I drive and don't sightsee. I try to drive ahead where I can see road conditions and problems. I'm not shy about running 2800-3000 rpm when necessary, the truck can tow easier at ~2000rpm/~60 mph, but the extra speed is necessary to get over hills without holding up traffic behind me. My truck has done real good for what it is, but it is time to make it better.
BTW, look at my sig. Im 2wd, stock tires, 4.10 etc. Only mod done to truck is a custom air intake I built many years ago. Quite a bit of difference from the 4wd, bigger tire models some folks tow with.
