i think fuel pump took a crap.
Greenbeast6.9
grease monkey
Tennessee
it figures just before the get together it is giving me problems!!!! I think i ran the front tank dry, or close to it and it is my diesel tank. I was going down the road and it was revving up like i had air in the lines then it would dog down i put it on the rear tank (WVO) and it seamed OK. i went into a store came back out and headed for home when i switched to the front tank, after a little while it started acting up again, i made it home and was messing with it in the drive way when it died, so i put it back to the rear tank and now it will restart but it quickly dies. I am getting some air out of the schrader valve and then a little fuel but it wont stay running!!!:puke: I even took off the filter and cranked it to see very little fuel (WVO) coming out, i know that tank is full, so am on on the right track to say it is the pump?:dunno
HELP!!!:hail
Greenbeast6.9
grease monkey
Tennessee
:yell: ok i got it running again, i put 17 gal in the front tank!!!cookoo :rotflmao I still think it is not pumping enough volume.
On a side note i am having an alternator problem, i have fried the plate looking thing on my alternator that is on the top back. I thought there was a wire going to it but i cannot find one anywhere!!!!! -cuss where and what does it do? also i have found that by grounding the rear most post (on top) i am getting charge???? What am i doing here? I know i need a new alternator because the post terminal that the plate bolts to is loose and flopping inside the alternator.:eek: Could someone shed some light on this or give me a picture of their 6.9 alternator from the top? Please help on this as i drive it daily.:dunno
FordGuy100
Silverton, OR
Yup, I'm thinking your fuel pump is crapping out on you. Are you using the mechanical fuel pump, or an electric one?
PRTJ. Happens every year about this time for those attending. LOL
