gunz
I run mix in my front tank. Well less than most of you. I start adn stop on diesel just in case, but when I have forgotten I have had no issies starting her up. Good GPs help a lot.
I have had bad luck with unleaded blends as well. They worked ok in my truck just running around, but when I put it in the John Deere working it hard it would lose power over time. Once it cooled it would run ok for a while. Eventually on a large field bushogging it just got hot and quit. I ran a bottle of diesel purge through it and swore off the unleaded blends and it has been fine eversince. I didn't click on the link but I guess it has to do with the difference between octane and cetane.Running gas is a bad idea. I was running 15% gas to 85% wmo. Every time I worked it hard, it would foul up my injectors with black grit. I killed injectors on a regular basis. It turned out to be the gas burning in my injector tips. OLDBULL8 pointed me towards this article. After reading that article, I switched to 30% diesel to 70% wmo and have not had any more injector trouble. I start up and shut down on diesel.
If you start up on wmo, do not increase rpm past idle for at least 5 minutes. I do not recommend trying to start on anything more than 50/50.
Follow the link in this post:
http://www.oilburners.net/forums/showpost.php?p=575380&postcount=4
