New guy here. Not my first IDI but the first I've torn down and fixed up. The truck is the one in my sig, a '94 factory turbo CCLB. I bought it in January and it was a hard start then. I figured it was a combo of dead GPs and a bad lift pump. When I was redoing most of the truck mechanically I replaced those things and it's still a hard start. It has to crank 5 or 6 times before it'll fire then it'll die right away. You kick it over again and it will fire and stay running. I've been building this truck to be reliable and so far that's a huge issue in my trusting it. If you shut it off and turn it over again it'll fire right up. It's when it sits for awhile is when it won't fire. Awhile meaning a few hours. It sounds like to me that the fuel isn't staying up in the lines. I've tried another lift pump but it still does the same thing. Could it maybe be a cracked fuel line somewhere? I've also changed the copper line from the lift pump to the filter with no change. Other ideas? My Ranger is dying so I really need this thing on the road soon.
Next is my biggest headache so far. So much so I should have put this first. Exhaust... Does anyone make a complete 4" turbo back kit with a 3" downpipe for my truck? Just looking for a straight pipe with a single exit. Turbo should help keep it quiet enough. I can find them for PSDs but I can't for the IDIT. I would prefer cheap. Winter layoff is coming and i'm already over budget with this truck. More or less I'm running out of money for this thing. Chasing fuel problems and other odd and ends are nipping at me. The only thing I haven't done is call an exhaust shop to see what it would cost to build one. I will be following what a few others I've seen on here do which is cutting off the flange on the elbow too then maybe put the downpipe directly in instead of playing with flanges. Unless you all think it's required otherwise. I'm not looking for anything fancy. The exhaust is just rotten and I might as well get rid of the restrictions that Ford forced onto us. If no kit exists what would I have to do to adapt say a Diamond Eye PSD exhaust to work?
Also 4" or 5"???? Pros and Cons?
