I have a leaker after injector replacement
Your cap be bad. As from your posts you stated that everything was new and it leaked... So you removed the injector and replaced the copper gasket and o-rings... Still leaks so... The cap is the only thing left. If you going to change locations use the number 2 cylinder. Its right up front of the drivers side head... No fuel filter in the way so its much easier to reach. About cleaning off the molding flash. Yes... I use an exacto knife around the very bottom of the cap. You can actually feel some ruff sharp flash sometimes...
truckonfire
