Hard start
I have 94 7.3idi just installed facet electric fuel pump and it is still hard to start
  • Any
    Votes: 2 100.0%
  • Any
    Votes: 1 50.0%
  • Total voters
  • Poll closed .
Jkelley
Stockdale tx
I have a 94 7.3idi just installed facet electric fuel pump and it is still hard to start any suggestions
sjwelds
Central KS
Electric fuel pump won't fix air intrusion or weak batteries or starter.
Jkelley
Stockdale tx
New batteries it appears to turn over very well just put new seals on fuel injectors it Wil fire quick when I put a little gas into air tube
chillman88
Central NY
How old are the glow plugs? You just said hard start, you didn't specify what it's doing.
You’re getting air somewhere. Check everything for a leak. Common places are fuel filter housing, soft line at the frame rail and any hardline connection where there is an olive.
Sidewinded_idi
Yucaipa ca
When it’s cold in the morning it cranks a lot aswell? Same as if it’s hot and you try to start?
Jkelley
Stockdale tx
In the morning it's very hard but after it runs and warms up it ok until you leave it set for about 45 min to hour then it's hard to start it run great when it starts
chillman88
Central NY
Might not be a bad idea to try some fuel rated clear tubing to find your air bubbles.
Sidewinded_idi
Yucaipa ca
Could almost be a injection pump failing as well as bad glow plugs. When cold with the bad plugs it takes extended cranking to light off. Test it by plugging your block heater in the morning for an hour or so and see what it does. The ip once the truck is warmed up it heat soaks the wore out ip
red41neck
Georgia
Interesting, fellow at swap meet last week said he could only get his early 94 7.3 started by putting air pressure in the fuel tank.
How ?? Why ??
placidoert
