got a little problem,need help
tbryga
cookeville TN
the truck is shakeing at idle,if i press the clutch in it will stop shakeing a little bit,its hard to get in reverse and hard to shift.im thinking the slave cylinder or the clutch is going out.does anyone have any idea what could be the problem
fx4wannabe
Chattanooga, TN
Sounds to me more like a bad flywheel. The factory flywheel is in 2 pieces and when it wears out and comes apart it starts shaking bad. I would get another opinion or two but that is my thought
sle2115
NRA LIFE MEMBER
Southeast Ohio
Need more data, what year? Trans? etc.
If it is a pre-dmf (two piece flywheel), it could be the firewall is cracked, not letting the clutch release properly as well.
troupp
Roaring Branch, pa
sounds like a bad pilot bearing. have done a couple with similar symptoms. pilot bearing either seizes and keeps input shaft turning, or explodes and drags parts around the shaft and keeps it turning.
tbryga
cookeville TN
i went out to the truck today,fired her up and everything was fine,no shakeing,went right in gear.im thinking i might have bad fuel or theirs water in it.im just going to get some fuel treatment and see what happens
