Good place to buy the injector hard lines
fx4wannabe
Chattanooga, TN
I got the truck running again finally and now I am working out some of the other kinks. Still have a fuel leak and I think its coming from the front hard line by the filter. I just put all new return lines, caps, washers and injectors on it so pretty that none of that is the problem. Seems to be come from where the line connects to the top of the injector. Everything is tight.
6 Nebraska IDIs
Someone probably cross threaded it or something. Best place to buy them from is a member here that happens to have the one you're looking for or find a set at your salvage yard. Everytime I find an IDI in a yard I pull all the hard lines because there's an easy $400 value just in the set of lines. And most yards will let them go for around $75. Always a good idea to have an extra set around.
4x4TruckinGirl
"Cowgirl"
Dixon, MO
I'm sure you can find some closer but I know Williams Diesel in Ocala, FL sells them individually..... I would check junkyards and such first though....
suv7734
BC Canada
If you have to go new these guys have a good reputation.
Make sure all the line clamps are in place (4 places) or the vibration will cause the lines to crack.
