Fuel pickup tube pre filter
HammerDown
Glenolden Pa
My OE shower heads lasted 24 years (can't complain about that) then melted away and fell off into large pieces.
I pulled both tanks and just added the 'proper-submersible' fuel line.
While the tanks were out I gave the outsides an acid bath to dissolve any rust then neutralized the acid etching with baking-soda and water then, fully painted the tanks with rustoleum.
HOWEVER...on the outside of the fuel tanks I did add an inline filter...reason...if I added some type of filter/screen on the inside and it became blocked I would have to drop the tank to remove the debris!
With the inline filter on the outside of the tank that allows me to simply remove the filter.
BTW I used a WIX #33972 transparent filter designed for diesel fuel.
tbrumm
Richland Center, WI
BTW I used a K&N transparent filter designed for diesel fuel.
[/QUOTE]
Ray - can you redo your attachment? - I am interested is seeing the filter you used. Thanks! Todd
HammerDown
Glenolden Pa
Sorry Todd, but the attachment doesn't show the filter.
Correction, the diesel rated filter is a WIX #33972
I believe Summit Racing shows a pic of it.
vegas39
las vegas, nv
There is no reason to dread changing the showerhead on the front tank, as the tank doesnt need to be dropped. The last time I modified my 89 front tank, it was only a matter of several minutes to have the assembly pulled out, modified and re installed.
Gerhard
