The valve you are looking at is made by a company called Pollak. They made these valves for Ford, and Ford specified a special wiring connector and line fittings and orientation. That is the $260 valve.
You can buy this same valve, made by the same company from the local parts store. But it is a universal valve. The function is exactly the same, but the wiring is a little different, and the fuel line fittings are different. With a little modification you can make it work. It's about $80 from the parts store.
There are many people who look for alternatives to this setup after changing the valves a few times over the course of owning these trucks. If you look in the project sub forum, there is a article in there where people use manual brass valves to do the switching along with a electrical switch for the sending units.
Then some people do away with the dual tanks and run one large tank in the rear. Then others have tried using the two tanks, but using a transfer pump to move fuel from one tank to another without a valve.
