Fuel filter heater?
Greg5OH
MI
I have long ago deleted my stock fuel filter head heater due to leaks. In its palce i have (i believe) an M12 plug. Wondering If can take that out, or put a recuding adapter in there, and run a little rod heater directly into there? Or can i drill the venry center of it and put something like this in?
Im just not paying 190 bucks for a brand name heater like that, since out block heaters are 1000W and OEM for about $30!!
Anyone know what this type of heater pictured is called?
Unsure if i want to do 12v on a circuit off the batteries, or have a 120V and have it tied in with my block heater..
laserjock
Almost there...
There is not much room in there for that type of heater. If you are worried, I'd get something that wraps around the fuel filter. Where you are, gelling the filter is a possibility even if the fuel is treated.
The wrap heaters seem to work well for those who use them.
I think I've even seen injection line heaters.
Greg5OH
MI
Wrap filter seems to be the easiest. I found a company that makes them, 1/4" diameter with an 1/8" NPT head, 2" long with 118W output
That is plenty small for that, however needs a minimum 10 orders to make them.
ONly thing I dont like about the wrap around heaters is 1) expensive 2) have to take it off when changing a filter
Matt_INW
Washington
I'll be interested to see what you get, and the results. Had to delete mine due to leaking too. It does get cold here, but not like MI.
Really not a win win situation here.
I guess you could swap to a better filter head. Still uses a spin on bottom also, which contain a heater.
Something like this. http://m.ebay.com/itm/221398942179
The reason this would be better, heat rises. The heater is at the bottom.
What you're trying might work. I would choose carefully on the fittings you use. Go for better heat transferring materials.
Greg5OH
MI
nice! those are a great price! 1/3 of other brands that look the same. I like the lace up deal.
Im not running diesel fuel right now, running ****** 15w40 oil as fuel with various blends of gasoline and kerosene.
My latest blend was only 10% RUG and the truck did NOT want to start in 65F weather whatsoever. Took a solid 5 mins of cranking, once fired off it ran great.
Best way is to run a 2 tank system, but I only have the one 44g rear tank, so cant start and stop on diesel.
FORDF250HDXLT
Maine & Oklahoma
oh.well i wonder if a small heater blanket like this could be wrapped around the IP with a toggle switch and or timer.since the start up fuel will be in the ip already,one would think this being heated up before any cranking was done would the quickest way to get her to light off.
Rot Box
Northern Utah
Lewiston
Random thought.. My VW recirculates fuel from the return lines through the fuel filter to warm it up.. Works good I think. Wonder if something like that is possible/worthwhile on the IDI :dunno
Greg5OH
MI
^yes a heater over the IP would be ideal!
PS plugged in the morning for an hour and it fired right off. But again, 60F outside, probably wont light off plugged in during the winter if I run this thick of blend.
First plan of approach is to thin my mix down, as its unnaceptable to have to plug in at these warm temps.
20% kerosene is next plan of attack, as 20% RUG resulted in high EGTs.
If the blend doesnt work, I will use one of those silicone heater pads wrapped around the IP.
Put it on a 10 minute timer off the batteries-experiemnt with how long it needs. Hopefully it leaves enough juice in the batteries to light GP then turn the thing over though.
