FS: 87-91 ZF5 2WD changeover kit.
Status
Not open for further replies.
If you're looking to put in a manual trans in where the auto trans was living, this kit is for you. everything except the driveshaft is included to get the job done.
what's included.....
ZF5 trans.
plug-n-play wiring harness section for neutral override and reverse switch.
clutch hydraulic assembly( master/tubing/slave)
clutch assembly (DMF/disc/pressure plate/throw out bearing/fork)
pedal assembly for 87-91 truck.
manual trans steering column(tilt wheel type)
cab floor plate with well abused shifter ******.
if you have a 83-86 truck, the pedal assembly can be substituted instead.
$800.
shipping not included.
Coyote_Red
Chelsea, Mi
Why do you have to be SO far away!! Shipping would run close to your asking price.
Status
