rhkcommander
This is my worklog for the Dana 44 TTB:
Questions at the bottom. First what I've done skipping the obvious:
When I came to the spindle nut, I found it was a 4-pronger. I was 99% sure it was before but in another rebuild thread I heard it could be 4 or 6. Autozone only had the 6 for rent, but had a 4 for sale. It was a 4
__________________________________________________________
Question:
Any info on tightening things? Like torque spec for the tie rod nuts, ball joint nuts, etc? Or do I just get em as tight as comfy?
Question:
This is as far as I've gotten, what else do I need to do to get the ball joints out? I've got the top BJ nut off and the clip off the bottom one.
If I run into any other problems I'll ask away. I'll take photos as I go so maybe this can become an article for future user reference
- May 11th
- Took wheels off
- Took the calipers off by pushing those weird slide in clips, tied them onto the frame
- Took the 6-allen 9/64 hub screws off
- took the snap ring and other ring off, took the philips screw out, pulled parts out.
- Removed all 4 tie rods, the drag link (big one) may have been fine but not the others
- May 12th
- Pulled the spindle nut, spindle etc.
- pulled the dust shield after removing 8 nuts
- working towards balljoints.
Question:
Question:
. I mostly just need a brain, I can do the grunting
