So I've got the truck all finished, painted, running good and no more HARD STARTS! Thanks to this forumhttp://www.oilburners.net/forums/images/smilies/biggrin.gif. Now I'm starting on the logging side of this little deal that I'm working on. I have a hitch on the front of the truck that I plan on using to mount a jib crane to. the crane is 10' tall and has a 9' reach. I'm guessing that it weighs roughly 550 lbs. I'll be using it to load and unload logs when logging etc. I'm going to tie the jib crane into a truck rack for added stability. Then when in use I'll support it further with jack stands or some other supports.
My question is, how much weight can the front of these trucks handle? It's a 89' f250 extended cab. I need to get some pictures up.
